Старый 18.05.2014, 01:54   #1
In this small tip I will show you have to export images from a RDLC report in NAV 2013 R2. You can do this in NAV 2009 and NAV 2013 also, but then you need to convert the Excel Spreadsheet to the latest version.
Scenario A: You have embedded a image into a RDLC report and no longer have access to the original image, and for some reason you need to extract the images out of the report.
Scenario B: You would like to export i.e all item images so you can have access to all them in one folder, for this you will of course need to create a report which runs through all items and shows the image. If you don’t have a report like that, have a look at my demo report here: http://1drv.ms/1qLDYRj
Here is what you need to do.
1. Print your report to Excel and save it to disk as Report.XLSX. In NAV 2013 R2 the report will have the extension XLSX. Notice that neither NAV 2013 nor NAV 2009 will produce XLSX format here you will get XLS, the old Office 97 format.
2. Rename the Report.XLSX to Report.ZIP
3,. Now open the Report.ZIP in Explorer
4. Navigate to the folder “XL/MEDIA” and here you will find all the images which are in the report.
Note to do the same in NAV 2009 and NAV 2013, save the report as Report.XLS, then open the report.xls in Excel 2007 or newer and save as XLSX format. Then you also have access to the images, by renaming the Report.xlsx to Report.zip.
/Thanks, Claus Lundstrøm, MVP for Microsoft Dynamics NAV
Abakion.com & Supplychainbox.com
Читать дальше
Часовой пояс GMT +3, время: 01:15.
