Старый 26.09.2016, 18:12   #1
organicax: Default cost group – direct materials
Источник: https://organicax.com/2016/09/26/def...rect-material/
If you are setting up costs groups you might want to consider the effect of the default costs groups. These can be applied to the different cost group types for example direct materials. So if the item doesn’t have a cost group assigned then the default cost group will be applied.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Microsoft Dynamics AX, Production control
dynamics-coe: “Cost accounting” for multi-level process manufacturing Blog bot DAX Blogs 0 11.02.2016 22:12
atinkerersnotebook: Using Dynamics AX To Calculate The Cost Of Your Breakfast Blog bot DAX Blogs 0 03.01.2015 18:14
NAV Team: Simulation of Average Cost Calculation Blog bot Dynamics CRM: Blogs 0 13.01.2012 16:54
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
Часовой пояс GMT +3, время: 14:52.
