Старый 15.10.2016, 08:12   #1
organicax: Vendor invoice participant provider for user selected approver
Источник: https://organicax.com/2016/10/14/ven...cted-approver/
In a previous post we had a look at a invoice workflow example where the user can select who the approver will be. In this video we’ll do a walk through of the customization to create a new workflow participant provider.
Here is an overview.
AX2012 R3 CU11
If you want to download an XPO of the code from the video you can find it on my OneDrive
https://1drv.ms/u/s!AjyKH96OSFD9gQ0gxgE9wFZDEnAO
This is AX2012 R3 Cu11 but the concept was similar in any release of AX2012.
If you want some more background on the workflow providers here are a few links
https://msdn.microsoft.com/en-us/library/hh528513.aspx
https://msdn.microsoft.com/en-us/lib...33997(v=ax.50).aspx
Cheers
Lachlan
Filed under: Accounts payable, Workflow
organicax: Vendor invoice approver workflow – user selected Blog bot DAX Blogs 0 15.10.2016 01:36
organicax: cXML punchOut protocol handler for AX2012 Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: cXML punchout protocol handler installation for AX2012 R3 Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: WMS Mobile Device indirect menu items – compile of posts. Blog bot DAX Blogs 0 03.09.2016 01:24
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
Часовой пояс GMT +3, время: 00:16.
