Старый 25.10.2016, 09:11   #1
palleagermark: SQL Server trial license expired on your cloud boxes for AX7?
Источник: http://www.agermark.com/2016/10/sql-...xpired-on.html
If you have made deployments before summer, you might have deployments where the SQL Server is installed with a trial license and it is set to expire november 1st. When it expires you are not able to start the SQL Server service anymore.
Here are the necessary steps to update SQL Server:
  • Obtain a valid installation media and license.
  • Stop the "Hyper-V Time Synchronization Service" service.
  • Change the system date on the server, to a date before the trial expiry date.
  • Run SQL Server installation and choose "Upgrade from preview version"
  • Start the "Hyper-V Time Synchronization Service" service again.
The reason for changing the system date is that the upgrade won't run if it can't start the existing SQL Server service.
german_nav_developer: “Wutschen und Wedeln”: Sortieren und Filtern in Dynamics NAV - Unterschiede zwischen SQL Server und Native Blog bot Dynamics CRM: Blogs 0 20.05.2011 21:06
dynamicsusers: Blocks & Deadlocks in NAV with SQL Server Blog bot Dynamics CRM: Blogs 0 18.04.2008 10:23
NAV Sustained Engineering Team Blog: Overview of updates for SQL Server 2005 SP2 Blog bot Dynamics CRM: Blogs 0 11.01.2008 17:49
Часовой пояс GMT +3, время: 21:49.
