Старый 09.11.2016, 18:11   #1
axinthefield: SQL Server Data Compression for Dynamics AX Part 4 – Actions post compression
Источник: https://blogs.msdn.microsoft.com/axi...t-compression/
In part 1 of the series we discussed Costs and Benefits of data compression together with some Best Practices to successfully compress your database. In part 2, we discussed the planning for Data Compression including prerequisites validation and steps to identify the best candidates for compression. In part 3, we showed you two different approaches...
emeadaxsupport: How to perform a data center change (change of the physical location) where a SQL server 2008 R 2 cluster installation and MS Dynamics AX 4.0 is involved? Blog bot DAX Blogs 0 21.06.2014 19:19
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
Часовой пояс GMT +3, время: 00:30.
