Старый 16.11.2016, 16:11   #1
emeadaxsupport: Error prompt “voucher number [Voucher Number] is already used as of date [Date]”
Источник: https://blogs.msdn.microsoft.com/axs...-of-date-date/
We have 3 workaround solutions for this a.       Mark the Number allocation at posting setup in Journal forms https://technet.microsoft.com/en-us/.../aa556237.aspx                       https://technet.microsoft.com/en-us/.../aa552517.aspx                      b.     When you get the error message find the number sequence that is having the issue , Organization administration/Common/Number sequences/Number sequences   select that number sequence, click on Manual Cleanup>current   Note... Read more
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
Dynamics AX Sustained Engineering: One voucher number only and Transaction Date in Journals Blog bot DAX Blogs 0 27.05.2010 23:05
Dynamics AX Sustained Engineering: One voucher number only and Transaction Date in Journals Blog bot DAX Blogs 0 22.05.2010 04:11
Часовой пояс GMT +3, время: 02:56.
