Старый 24.11.2016, 02:13   #1
newdynamicsax: Extending an extension: Here's a simple example with field groups
Источник: https://community.dynamics.com/ax/b/...h-field-groups
In some cases, your customer or partner will need to customize your application using extensions, but may find themselves having to extend an element that is already an extension. In other words, if you...(read more)
newdynamicsax: Code behind extension forms: How to add state variables and override methods without overlayering Blog bot DAX Blogs 0 12.10.2016 06:25
stoneridgesoftware: Using Field Groups when Creating New Fields in Dynamics AX Blog bot DAX Blogs 0 26.05.2016 18:11
newdynamicsax: How do I access an extended table field from C#? Blog bot DAX Blogs 0 29.04.2016 02:18
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 09:09.
