Старый 01.12.2016, 15:11   #1
palleagermark: First place to look when batch seems not be working i AX7
Источник: http://www.agermark.com/2016/12/firs...tch-seems.html
When you can see that the batch service is not really picking up any jobs, the first place to look is normally in the batch group setup. Here you'll validate that the different batch groups are connected to a batch server.
And here comes the fun part where AX7 might trick you, if you not on your toes. The selection panels for Selected and Remaining servers have switched places since AX 2012...
Here is the dialog in AX 2012:
And here it is in AX7:
A thank you goes out to Lau Larsen for pointing this out.
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
palleagermark: Working with Excel files in AX7 Blog bot DAX Blogs 0 28.12.2015 10:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Platform updates overview - 3.70.B - NAV2009 R2 Blog bot Dynamics CRM: Blogs 0 07.02.2011 22:06
Часовой пояс GMT +3, время: 01:25.
