Старый 08.04.2017, 02:14   #1
organicax: Setting up a quality test group
Источник: https://organicax.com/2017/04/07/set...ty-test-group/
When you are managing inventory or production there maybe times where you need to test the quality of a product. This could range from a simple inspection to an advanced sequence of test through a laboratory process. It really depends on the products and processes.
AX has a quality module that allows tests to be setup and then capture some feedback from the inspection or test. Sometimes you just need a mechanism setup in the business system to indicate or record a test was done but the actual test is done and record in an external system especially when there are complex labs. The good thing is the process control that you can use the quality module for in AX.
To use quality association that trigger a quality test you will need to setup a test group.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control, Quality control
dynamicsaxtraining: Quality management Blog bot DAX Blogs 0 12.02.2011 00:11
NAV Team: Test Automation and Test Data Blog bot Dynamics CRM: Blogs 0 01.10.2010 12:56
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
Khue Trinh: AX 2009 Quality Management - Quality Control Blog bot DAX Blogs 0 04.05.2009 14:05
Khue Trinh: AX 2009 Quality Management - Quality Control Blog bot DAX Blogs 1 04.07.2008 16:01
Часовой пояс GMT +3, время: 14:43.
