Старый 02.11.2017, 22:11   #1
everythingdynamicsaxbi: Errors when trying to generate a forecast using Demand Forecasting (AX2012)
Источник: http://www.everythingdynamicsaxbi.co...asting-ax2012/
I was setting up Ax2012R3 to use the Demand Forecasting functionality and it wasn’t that straightforward as I thought. I began deploying the Demand Forecast database from SQL Server Analysis Services wizard:
After that I configured a scheduled refresh for the cube in the SQL Server Agent. After trying to generate a forecast I got an error saying:
So I followed the link in the infolog and went on installing the Microsoft SQL Server ADOMD.NET on the AOS server:
Ok good. Went on trying to generate a forecast again, but then another error popped up saying:
Not very informative at all. This could mean a lot of different things, but it is related to permissions. Security in the SSAS cubes are handled outside of AX, so I connected to the Demand Forecast SSAS database and added the AOS Service Account and my user to the “Production Planner” role. I then processed the cubes and voilà, the forecast was generated without errors
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
Axilicious:AX2012 R2 – Hidden compiler errors – Update Blog bot DAX Blogs 1 10.03.2013 09:31
ax-erp: Debug BP errors in Dynamics AX 2012 Blog bot DAX Blogs 0 14.12.2012 23:11
NAV Team: Forecast netting in NAV: where the buckets are!!?? Blog bot Dynamics CRM: Blogs 0 10.10.2011 12:13
Часовой пояс GMT +3, время: 12:09.
