Старый 23.04.2018, 05:12   #1
lcs: Rotate the expired or nearly expired SSL certificate on your subscription’s one-box environments
Источник: https://blogs.msdn.microsoft.com/lcs...-environments/
On April 23 2018 17:00:00 UTC, the SSL certificate on one-box environments that are under your subscription and not managed by Microsoft, will expire. Project owners or Environment managers can rotate the certificate from LCS. If you do not rotate the certificate, when you try to use Dynamics 365 for Finance and Operations or Dynamics 365 for...
lcs: Notice of upcoming change: Removing RDP access to Tiers 2, 3, 4, and 5 Standard Acceptance Test (or Sandbox) environments deployed in Microsoft subscription Blog bot DAX Blogs 0 27.02.2018 09:12
lcs: Notice of upcoming change: Removing Azure SQL Server administrative access to Tiers 2, 3, 4, and 5 Sandbox environments deployed in Microsoft subscription Blog bot DAX Blogs 4 19.12.2017 15:08
lcs: Guidelines for Tier 1 Dev, Test, and Build environments deployed in Microsoft’s subscription Blog bot DAX Blogs 0 01.07.2017 02:17
Rahul Sharma: Dynamics AX 2012 R3 Mobile Apps Configuration Using Self-Signed Certificate Blog bot DAX Blogs 0 05.05.2015 08:14
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
Часовой пояс GMT +3, время: 08:04.
