Старый 31.05.2018, 09:12   #1
stoneridgesoftware: Exporting Text Format Positive Pay File in Dynamics 365 for Finance and Operations
Источник: https://stoneridgesoftware.com/expor...nd-operations/
In Dynamics 365 for Finance and Operations, the default format of the Positive Pay output is XML. Microsoft has provided steps for the setup of Positive Pay as well as a sample XSLT file used to transform the output.
However, it is possible to create your own XSLT file for text or CSV format. The following sample code creates a fixed length text file but could be modified easily for CSV format. Note the output method highlighted below. Here is a link to the string manipulation functions used in the sample.
It is important to note that when generating the Positive Pay file and the Open or Save prompt appears, you must change the file type to Txt. See the following screenshots.
1. Upload the transformation file as per the instructions in the link at the beginning of this article.
2. Generate Positive Pay
3. Select Save As and save the file as Txt.
Special thanks to my teammate Karl Gunderson for lending his XSLT expertise to this project on how to export a text format positive pay file in Dynamics 365 for Finance and Operations.
survivingcrm: What’s An “App” in Dynamics 365 Anyway? Blog bot Dynamics CRM: Blogs 0 06.01.2018 22:14
stoneridgesoftware: Identifying Roles for Security in Dynamics 365 for Operations Blog bot DAX Blogs 0 19.05.2017 19:11
jaestevan: Microsoft Dynamics 365 for Operations Blog bot DAX Blogs 0 02.11.2016 01:11
Platform updates overview - 3.70.B - NAV2009 R2 Blog bot Dynamics CRM: Blogs 0 07.02.2011 22:06
Часовой пояс GMT +3, время: 03:37.
