Старый 17.08.2018, 22:12   #1
powerobjects: Understanding CRM Solutions For Microsoft Dynamics 365
Источник: https://www.powerobjects.com/2018/08...-dynamics-365/
In this blog, we will highlight a few key points of a solution including a solution overview for Microsoft Dynamics 365 (online and on-premises), Dynamics CRM 2016,  and Dynamics CRM Online. We’ll also cover how solutions operate (managed and unmanaged), and how to create a solution.
Solutions are a group of components that can be exported and imported into any CRM environment. It may work best for developers to create a solution and make changes within a Sandbox or non-live environment prior to exporting it to a Production instance.
Microsoft Dynamics 365 out of the box functionalities come with pre-configured entities, such as – Leads, Contact, Accounts, and Email, etc. As for the solution component, there are many items that are customizable.
After the Solution is created you may create different Entities with customized components. Some of the existing Entities would then come with Forms, Views, Fields, and Dashboards, etc. The purpose of a solution component is to keep track of what is customized using what are called managed or unmanaged solutions.
Exporting a solution provides you with two different options. Exporting a managed or unmanaged solution is different. An unmanaged solution essentially allows you or the new user to make changes to the solution after you have already imported the new solution. With a managed solution, this essentially locks in those certain changes you have made. Every time these are imported, those changes cannot be changed and allows you to lock those in.
Let’s walk through how to create a solution:
Creating a solution:
1. Open the necessary environment you have and navigate to the URL.
Ex: https://yourorganization.com.dynamics.com
2. Within the navigation bar, click on Settings.
3. Lastly, click Solutions underneath the Customizations heading.
4. After clicking on the New button, a solution form will be displayed. The following is an example of what the solution form should look like.
5. Now you may create the display name and enter in the Version Number dependent on your organizations need.
Finally, you should know some things before using Dynamics 365 CRM solutions. If you have a managed solution within a Sandbox environment and that was removed, you will run into the issue of not being able to make original changes. So, if there is any doubt, please remember to export both a managed and unmanaged solution.
Looking for more Dynamics 365 tips and tricks? Be sure to subscribe to our blog!
Happy Dynamics 365’ing!
powerobjects: Dynamics 365 as an Application Integration Platform Blog bot Dynamics CRM: Blogs 0 13.04.2018 02:16
dynamics-coe: Integrating Microsoft Dynamics CRM 2011 Online with Java and other non-.Net Clients Blog bot Dynamics CRM: Blogs 0 21.09.2013 13:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Online Test Drive Guide Blog bot Dynamics CRM: Blogs 0 05.08.2011 20:13
Jim Wang: Software Advice: 15 Favourites Microsoft Dynamics CRM Industry Solutions Blog bot Dynamics CRM: Blogs 2 26.08.2010 02:09
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 Blog bot Dynamics CRM: Blogs 0 04.06.2010 13:21
Часовой пояс GMT +3, время: 10:58.
