Старый 25.01.2019, 02:32   #1
goshoom: Splitting .xpo files
Источник: http://dev.goshoom.net/en/2019/01/splitting-xpo-files/
I got an .xpo file from an older version of AX with some code of interest and because it had a few thousand lines, it wasn’t exactly easy to navigate. At least splitting it by object would make my life much easier.
Fortunately I looked at the internet and found exactly the right tool for this task: xpoTools.
It’s not well-documented, but what I needed didn’t require much anyway. After installation, I simply ran the following (Powershell) code:
cd c:\Temp\XPO\ls *.xpo | Import-Xpo | Split-Xpo -Xpp
Import-Xpo parses xpo files to objects expected by Split-Xpo, which creates a file for every object. The -Xpp flag means that the result are not .xpo files, but rather more readable files with pure source code (without all those # characters and things like that).
This might be the last time I used this tool, but it did help me today. As often, a single search on internet saved me a lot of time.
Thank you, mazzy.
atinkerersnotebook: Configuring a BYODB and Creating a Full and Incremental Entity Export Blog bot DAX Blogs 0 25.05.2018 15:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 R2 Blog bot NAV: Blogs 0 15.05.2016 18:12
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
Gareth Tucker: Scribe Insight and Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 06.05.2012 02:18
Часовой пояс GMT +3, время: 19:30.
