Старый 27.03.2019, 01:12   #1
How to get number of rows loaded in a grid
Источник: http://alexvoy.blogspot.com/2019/03/...d-in-grid.html
In fact we can use numberOfRowsLoaded on a linked form data source; however, it shows the number of those cached only.
So, if you are editing row number 28, for example, and then call ExecuteQuery() on the data source, you will probably get a lower number of rows loaded in the grid yet, say, 19.
In order to get the right number, you should use the aforementioned method together with allRowsLoaded() one.
public int wblNumberOfRowsLoaded()
int wblNumOfRec;
int wblCounter;
wblNumOfRec = PSAActivityEstimates_DS.numberOfRowsLoaded();
// nothing to load yet
if(!wblNumOfRec)
return wblNumOfRec;
// so far we numbered those lines cached only
while(!PSAActivityEstimates_DS.allRowsLoaded())
// so let's move it on until the end of loading
PSAActivityEstimates_DS.setPosition(wblNumOfRec);
PSAActivityEstimates_DS.getNext();
// just to avoid never ending adventure
if(wblCounter>1000)
break;
wblCounter++;
// get the number for the next iteration
// now all numberOfRowsLoaded() calls will return the correct number of rows in grids
return wblNumOfRec;
ax-erp: How to get AOS Port number in axapta by code Blog bot DAX Blogs 0 19.10.2012 21:12
dax-lessons: How to get the count of number of pages printed on to SSRS report [AX 2012 , X++] Blog bot DAX Blogs 0 16.08.2012 21:12
Dynamics CRM Tools: How to colorize grid rows… Blog bot Dynamics CRM: Blogs 0 27.01.2012 01:12
Khue Trinh: How to get Inventory On-hand number Blog bot DAX Blogs 17 11.01.2008 22:23
Часовой пояс GMT +3, время: 10:46.
