Старый 30.06.2019, 11:12   #1
ievgensaxblog: MSDyn365FO. How-to extend product dimension lookup to add dimension description.
Источник: https://ievgensaxblog.wordpress.com/...n-description/
Recently I saw a question on community forum asking how to extend InventProductDimensionLookup form to add description column, it’s not an obvious task, so I decided to write small blog post about it.
InventProductDimensionLookup form is used to lookup all product dimensions, so we will add new display method to retrieve description from EcoResProductMasterDimValueTranslation table. Simple solution would be to extend form data source, but currently (PU27) there is an issue with display methods. Display method added directly to a form data source accepts current record but display method on extension does not accept anything. Without table buffer display method shows value based on a first record in the grid, that does not make any sense. To workaround this issue we will add new display method to a table extension and check if it is called from a form to grab data required.
[ExtensionOf(tableStr(InventDim))] public final class InventDim_IM_Extension { public display Name displayDimDescription_IM() { FieldId dimFieldId; EcoResProductRecId product; boolean isCalledFromnventProductDimensionLookup; if (FormDataUtil::isFormDataSource(this)) { FormDataSource dataSource = FormDataUtil::getFormDataSource(this); if (formHasMethod(dataSource.formRun(), formMethodStr(InventProductDimensionLookup, inventDimSetupObject))) { Object formRun = dataSource.formRun(); InventDimCtrl_Frm_Lookup inventDimCtrl_Frm_Lookup = formRun.inventDimSetupObject(); dimFieldId = inventDimCtrl_Frm_Lookup.parmMainSortFieldId(); product = InventTable::find(inventDimCtrl_Frm_Lookup.callerItemId()).Product; isCalledFromnventProductDimensionLookup = true; } } Name dimName; if (!isCalledFromnventProductDimensionLookup) { return dimName; } LanguageId userLanguageId = new xInfo().language(); RecId dimRecId; switch (dimFieldId) { case fieldNum(InventDim, configId): EcoResConfiguration ecoResConfiguration; EcoResProductMasterConfiguration ecoResProductMasterConfiguration; select firstonly RecId from ecoResProductMasterConfiguration where ecoResProductMasterConfiguration.ConfigProductMaster == product exists join ecoResConfiguration where ecoResConfiguration.RecId == ecoResProductMasterConfiguration.Configuration && ecoResConfiguration.Name == this.(dimFieldId); dimRecId = ecoResProductMasterConfiguration.RecId; break; case fieldNum(InventDim, inventSizeId): EcoResSize ecoResSize; EcoResProductMasterSize ecoResProductMasterSize; select firstonly RecId from ecoResProductMasterSize where ecoResProductMasterSize.SizeProductMaster == product exists join ecoResSize where ecoResSize.RecId == ecoResProductMasterSize.Size && ecoResSize.Name == this.(dimFieldId); dimRecId = ecoResProductMasterSize.RecId; break; case fieldNum(InventDim, inventColorId): EcoResColor ecoResColor; EcoResProductMasterColor ecoResProductMasterColor; select firstonly RecId from ecoResProductMasterColor where ecoResProductMasterColor.ColorProductMaster == product exists join ecoResColor where ecoResColor.RecId == ecoResProductMasterColor.Color && ecoResColor.Name == this.(dimFieldId); dimRecId = ecoResProductMasterColor.RecId; break; case fieldNum(InventDim, inventStyleId): EcoResStyle ecoResStyle; EcoResProductMasterStyle ecoResProductMasterStyle; select firstonly RecId from ecoResProductMasterStyle where ecoResProductMasterStyle.StyleProductMaster == product exists join ecoResStyle where ecoResStyle.RecId == ecoResProductMasterStyle.Style && ecoResStyle.Name == this.(dimFieldId); dimRecId = ecoResProductMasterStyle.RecId; break; } if (dimRecId) { dimName = EcoResProductMasterDimValueTranslation::getDescriptionOrDefaultDescription(dimRecId, userLanguageId); } return dimName; } } Now extend the form and add new control
If you cannot select data method from the drop down, compile class first and then it should be available.
Старый 01.07.2019, 04:38   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Четко. Как интерестно такое вообще проходит(если он есть в каком-то виде) контроль качества внутри микрософта. Я так понимаю исправить это в принципе теперь нельзя, так как старый код перестанет компилиться, а OneVersion должна гарантировать бинарную совместимость. RIP дисплей методы на форме
Старый 01.07.2019, 08:47   #3
skuull is offline
skuull
700 / 752 (27) +++++++
Там в 1 методе косяк, FormUtil класс или как-то так, туда приходит буфер, все с ним хорошо, а потом какие-то интеллектуалы из него получают датасоурс и передают его как параметр в dictClass.callStatic. На яммере 3 месяца назад писали, что об этом знают и баг в очереди но без PU, видимо не приоритет. Как будут чинить это вопрос хороший, наверное допишут костыль и будут проверять сколько параметров у метода, как уже сделано чтобы отличить edit методы.
Старый 01.07.2019, 10:18   #4
https://www.youtube.com/watch?v=MC96YUdWFt4
к концу 4й минуты видео в голове отчетливо проявляются цитаты великого мыслителя Нахуа.
к конце 13й минуты наступает дзен и разливается восхищение от тотальной бессмысленности труда создателей.
просто, чтобы было "красиво".
За это сообщение автора поблагодарили: twilight (1).
Старый 01.07.2019, 11:08   #5
skuull is offline
skuull
А чем "красиво" не повод? А то выходит что надо просто пойти и умереть.
Старый 01.07.2019, 11:11   #6
Сообщение от skuull Посмотреть сообщение
вполне.
а вариант "красиво" и "с пользой" совсем не рассматривается?
например, следующее видео от этих же авторов https://www.youtube.com/watch?v=hvEh8xrgqZY
вполне можно озаглавить "из говна и палок".
но впечатления от проделанной работы совсем другие.
Старый 01.07.2019, 11:17   #7
skuull is offline
skuull
ИМХО, польза и красота субьективные критерии. На лодке можно плыть, а в шалаше жить, но вот почему-то шалаш полезней...
Старый 01.07.2019, 11:21   #8
На лодке
лодке?!
Как скажешь.
Так выпьем за специально обученных людей, которые умеют продать этот продукт!
Старый 01.07.2019, 11:35   #9
skuull is offline
skuull
А что там было в первом видео? Не паравоз же.
Старый 01.07.2019, 11:42   #10
fed is offline
fed
Аватар для fed
2,914 / 5737 (197) ++++++++++
Мне показалось что это видео про карго-культ. Потому что лодка там была построена в далеке от воды, с щелями по всему корпусу да и еще и каркас лодки был вкопан в землю.
Старый 01.07.2019, 11:50   #11
skuull is offline
skuull
Для меня загадка откуда у mazzy такие познание в творчестве этих ребят А лодка настолько же хороша насколько и это блог.
Старый 01.07.2019, 11:57   #12
Му-ха-ха. И маззи плох, и блог гавно.
а запоротые display/edit методы - норм. как и тотально бессмысленная работа над текущими финасовыми аналитиками.
подкину дровишек:
блог бесплатный. а вот продукт за деньги продается выдается в аренду.
Старый 01.07.2019, 12:13   #13
skuull is offline
skuull
Мне блог нравится и лодка была красивая.
Я бы назвал их "недореализованные" display/edit методы. Проблема в том, что всем пофиг на их реализацию как и на много других мелких вещей.
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 2 – Format. Blog bot DAX Blogs 0 06.02.2019 07:12
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
How to lookup and set a new value for Financial dimension Blog bot DAX Blogs 0 03.10.2015 02:35
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
Часовой пояс GMT +3, время: 02:10.
