Старый 08.10.2019, 14:11   #1
crmtipoftheday: Tip #1311: Use entity name in Flow lookups
Источник: https://crmtipoftheday.com/1311/use-...-flow-lookups/
If you are building your Flows from solutions and connecting to Common Data Service, you should use the CDS (current environment) connector.
When you do, if you populate lookup fields, you might get a “resource not found” error message.
If you get this error, like I did, you are probably just putting the guid of the record in the lookup field. You need to also include the entity name in your reference.
Once you do, your lookup field should populate properly.
crmtipoftheday: Tip #1302: Should I recreate the account entity? Blog bot Dynamics CRM: Blogs 0 06.09.2019 08:12
crmtipoftheday: Tip #1276: Do my Dynamics 365 users need a Microsoft Flow license? Blog bot Dynamics CRM: Blogs 0 21.06.2019 19:12
crmtipoftheday: Tip #1258: Dynamic attribute names in Flow Blog bot Dynamics CRM: Blogs 0 26.04.2019 14:11
crmtipoftheday: Tip #1044: Display lookups as hyperlinks in portal entity list Blog bot Dynamics CRM: Blogs 0 15.12.2017 03:21
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
Часовой пояс GMT +3, время: 21:39.
