Старый 19.02.2020, 18:13   #1
a33ik: Filter objects into a project which are on several layers
Источник: http://daxonline.org/1678-filter-obj...al-layers.html
To collect objects which exists on two or more layers
  • To SysModelElement datasource add additional SysModelElementData (2) datasource
  • To SysModelElementData (2) datasource add additional SysModelLayer (2) datasource
  • Add range to SysModelLayer.Layer
  • Add range to SysModelLayer (2).Layer
Adding more datasource in similar way will allow to collect objects which are on 3 layers or more.
Query example:
To collect objects, which exists on two models
  • To SysModelElementData (2) datasource add additional SysModel datasource
  • To SysModel datasource add additional SysModelManifest (2) datasource
  • Add range to SysModelManifest.Model name
  • Add range to SysModelManifest (2).Model name
Adding more datasource in similar way will allow to collect objects which are on 3 models or more.
Query example:
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
stoneridgesoftware: Version Control in Dynamics AX: Check-in a project and all of its pending objects Blog bot DAX Blogs 0 11.11.2016 04:26
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
Часовой пояс GMT +3, время: 07:19.
