Старый 25.03.2020, 20:14   #1
thwidmer: Electronic Reporting on DEVBox
Источник: https://thwidmer.wordpress.com/2020/...ing-on-devbox/
If you do not have a connection to LCS on your DEVBox you can still access the new Microsoft definitions by doing the following:
Download the definitions from LCS
https://lcs.dynamics.com/V2/SharedAssetLibrary
“DOWNLOAD ALL” in LCSExtract in DEVBox
C:\Temp\SolutionRepository
Extract LCS ZipFile to C:\Temp\SolutionRepositoryAdd File System Repository
https://usnconeboxax1aos.cloud.onebo...mi=ERWorkspace
Edit the Microsoft RepositoriesAdd a “File system” repository. NOTE: This requires the debugger – see next step.Debugger required
Set breakpoint in ERSolutionImportRepository::getTypes() and use the debugger to add the ERSolutionFileSystemRepository type.
Import local definitions
Open the newly added file system repositoryImport the desired definitions – or import all if you like.
thwidmer: Electronic reporting by example: Create a new Bank file definition Blog bot DAX Blogs 0 31.01.2020 19:11
erconsult: Electronic reporting for data migration Blog bot DAX Blogs 4 17.01.2020 17:32
erconsult: Electronic Reporting (ER) Cookbook 2: new tips from the kitchen Blog bot DAX Blogs 0 06.08.2018 17:11
powerobjects: Electronic Reporting in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 14.02.2018 03:28
NAV reporting: Building a Matrix Report in Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 28.08.2009 18:26
Часовой пояс GMT +3, время: 16:06.
