Старый 07.04.2020, 04:14   #1
instructorbrandon: Techno-functional Dynamics 365 F&S Data Model Explanations for Reporting, Part 3 of 25 – Working with Item Receipt Tables
Источник: https://www.instructorbrandon.com/cr...ipt-part-3-25/
Now that you’ve learned how to register or reserve any purchased item from your inventory, it’s time to generate your first product receipt. Creating receipts is important and informative, as it confirms your customers have received your products. ​Receipts​ also allow you to process your purchase order lines (POs) for invoicing. Make no mistake, you can gather an amazing amount of information from receipts - if you know what to look for. After you generate the product receipt, the system creates an unchangeable voucher document.
The post Techno-functional Dynamics 365 F&S Data Model Explanations for Reporting, Part 3 of 25 – Working with Item Receipt Tables appeared first on Brandon Ahmad.
stoneridgesoftware: How to Pull Data from Microsoft Dynamics 365 into Power BI Reports Blog bot DAX Blogs 0 19.07.2017 20:13
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
NAV Team: Upgrading from Microsoft Dynamics NAV 2009 R2 or Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2015 Blog bot Dynamics CRM: Blogs 0 23.02.2015 13:00
dynamicsmatters: Dynamics Ax Base Data model Part I Blog bot DAX Blogs 0 02.12.2006 23:49
Часовой пояс GMT +3, время: 22:34.
