Старый 22.05.2020, 18:11   #1
goshoom: FormObservableLink works in data source extensions
Источник: http://dev.goshoom.net/en/2020/05/fo...ce-extensions/
FormObservableLink class is useful for refreshing display and edit methods in D365FO. You create an instance variable of FormObservableLink type in a form, initialize it and call its observe() method in display/edit methods that you need to refresh on demand. When the refresh is required, you call markChanged() method of FormObservableLink and the system will rerun the methods and display new values. You can find more details in AX 7. Display methods and Form Observability, for instance.
I wondered if I can do the same in a data source extension and I wasn’t really should that it would work. But it does – and the implementation is virtually the same as when building a whole form.
Here is a simple example:
[ExtensionOf(formDataSourceStr(smmContactPerson, ContactPerson))]final class MySmmContactPerson_ContactPersonDs_Extension{ // Declare and initalize FormObservableLink private FormObservableLink observableLink = new FormObservableLink(); edit NoYes myMethod(boolean _set, ContactPerson _contactPerson, NoYes _newValue)    { // This says that observableLink will be able to refresh myMethod()        observableLink.observe();         ....    } void refreshMethodsWhenSomethingHappened() { // Here we trigger a refresh observableLink.markChanged(); }}
survivingcrm: The Real Common Data Service Emerges Blog bot Dynamics CRM: Blogs 0 08.04.2019 22:12
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 10:41.
