Старый 07.07.2020, 06:34   #1
msdynamicsworld: Payment process automation in Microsoft Dynamics 365 Finance
Источник: https://msdynamicsworld.com/story/pa...cs-365-finance
For those working with Microsoft Dynamics, whether AX 2009, AX 2012 or even Dynamics 365 Finance and Operations, the usual approach to processing payments for a vendor involves creating a payment journal, and then processing a payment proposal.
However, to make it more intuitive and provide more automation capabilities, a new feature for payment processing has been introduced: process automation. This feature allows you to create a pre-defined schedule with a combination of payment proposal criteria to be able to create payment journals, with less user intervention. Note that this feature is controlled by the feature management in PU35 and would have to be enabled once PU35 is installed.
The first step with process automation is to setup a schedule. This can be setup under Accounts Payable-->Setup-->Payment-->Process Automations.
You can start creating a process automation by selecting “Create new process automation”.  You can see the schedule type that appears as “Vendor Payment proposal”.
The most interesting and advanced feature lets you schedule automation across companies (payment journals would be created in respective companies) without changing the company's day to day activities of using Dynamics 365 Finance.
Microsoft Dynamics CRM Team Blog: The Microsoft Dynamics CRM Swiss Army Knife Blog bot Dynamics CRM: Blogs 1 19.04.2012 08:20
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 19 Blog bot Dynamics CRM: Blogs 0 26.08.2011 01:13
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
Часовой пояс GMT +3, время: 20:51.
