Старый 15.10.2021, 01:13   #1
butenko.pro: HowTo: Open bulk editing of records using Xrm.Navigation.navigateTo
Источник: https://butenko.pro/2021/10/14/howto...on-navigateto/
According to the documentation Xrm.Navigation.navigateTo method doesn’t have any option to open bulk editing but investigating the code I found the way to do that. Here is an example of the code that could be used to open Bulk Editing: [crayon-616867a18a1e6925804549/] Key points here are passing “bulkedit” value to pageType, schema name of the entity ...
butenko.pro: Open proper form based on record’s data – UCI way Blog bot Dynamics CRM: Blogs 0 14.04.2020 05:20
butenko.pro: Xrm.Navigation.navigateTo – gotchas, tricks and limitations Blog bot Dynamics CRM: Blogs 0 23.12.2019 22:15
butenko.pro: HowTo: open plugin/custom workflow activity project created using CRM/D365 Developer Toolkit Blog bot Dynamics CRM: Blogs 0 26.11.2018 05:01
butenko.pro: UWT: Cloning record with related records with no code Blog bot Dynamics CRM: Blogs 0 27.04.2018 05:11
butenko.pro: Copying of N-N related records with no code using UWT Blog bot Dynamics CRM: Blogs 0 26.04.2018 10:11
Часовой пояс GMT +3, время: 06:47.
