Старый 27.07.2024, 07:50   #1
dynamicsaxinsight: D365: Refresh entity list batch job failing
Источник: https://dynamicsaxinsight.com/2024/0...h-job-failing/
Purpose:
Recently, I encountered an error on my DEV box while I was running Refresh entity list batch job after making some changes to one of the data entities. In this post, we’ll learn how can we resolve this issue.
Application:
Dynamics 365 for Finance and Operations
Error:
Entity * not removed because it belongs to the follow definition group or template.
Change Tracking is not enabled on the database: SQL Server Change Tracking.
Error encountered while creating entity data. Please contact your administrator if this persists.
Solution:
To resolve the issue, we need to enable change tracking for the SQL database. Given you have access to the database as this is your development environment, you need to run the following SQL command to enable change tracking for the database.
SQL
ALTER DATABASE AxDB SET CHANGE_TRACKING = ON (CHANGE_RETENTION = 2 DAYS, AUTO_CLEANUP = ON)
kurthatlevik: Batch Jobs; Take control of the executions Blog bot DAX Blogs 0 20.01.2020 20:13
atinkerersnotebook: Configuring a BYODB and Creating a Full and Incremental Entity Export Blog bot DAX Blogs 0 25.05.2018 15:11
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
dynamicsaxinsight: AX7/D365/Operations: Create custom data entity Blog bot DAX Blogs 0 14.09.2017 13:11
Часовой пояс GMT +3, время: 21:37.
