Старый 17.10.2012, 21:12   #1
ax-erp: Ax2012 Validate XML and Show XML in form
Источник: http://microsoft-dynamics-ax-erp.blo...l-in-form.html
The following sample job used to show any xml,XSLT,XSD schema in the form and validate that XML.
In this example I have the table with the xml value stored in it.
if you want to validate from file also we can do as well.
static void Krishh_LoadXmlform(Args _args)
ChangeOrderSourceLog sourceLog;
AifXmlViewer viewer;
select firstOnly from sourceLog where sourceLog.changeOrdernum='3369';
if(sourceLog )
// construct the AIFXMLViewer class object by the xml value and the type of the XMLFile.
viewer=AifXmlViewer::construct(sourceLog.ChangeOrderSourceXML,AifXmlType::XML);
viewer.show();
Microsoft Dynamics CRM Team Blog: Fetch-Xml based Reports: Bits & Pieces Blog bot Dynamics CRM: Blogs 0 24.02.2011 21:11
workflowax: Dynamics AX Technical Conference 2011 Blog bot DAX Blogs 0 20.01.2011 03:16
X++: Serializing Axapta Foundation Class instances as XML streams Blog bot DAX Blogs 0 04.06.2009 23:05
axStart: Getting Dynamics AX information into Dynamics CRM, the easy way. Blog bot DAX Blogs 0 15.07.2008 02:13
Часовой пояс GMT +3, время: 21:20.
