Старый 14.03.2008, 22:11   #1
mfp: Upgrading to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009
Источник: http://blogs.msdn.com/mfp/archive/20...s-ax-2009.aspx
Deepak Kumar and myself hosted a session on the upgrade process at Convergence in Orlando. A big thank you to everyone who attended; we are truly humbled by the great feedback we are receiving for our session. An even bigger round of applause is due to Paul Langowski from Tectura, who joined us on stage to give testimony on two "double-leap" upgrades he has worked on.
For those of you who wasn't able to attend, I've attached the slide deck to this post.
Here is the excerpt of the session:
Upgrading to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009; 3/13/2008 10:00AM-11:00AM; W204
This session will take you through the end-to-end flow of upgrading from Microsoft Dynamics AX 3.0 to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009. You will see an overview of the code upgrade as well as the data upgrade process along with recommended best practices. Examples of the improved upgrade documentation, with a focus on the implementation guidelines that come with a dedicated section for upgrade, will also be covered. This session will also include tips on performing data upgrade and code upgrade more efficiently and effectively. Additionally, you'll learn tips on the extra steps needed to upgrade if you've extended your solution. This session is designed for partners and customers who are planning to upgrade or would like to learn more about a Microsoft Dynamics AX upgrade.
Часовой пояс GMT +3, время: 07:41.
