Старый 03.05.2008, 08:16   #1
Developer notes: Null value for ADO command parameter
Источник: http://axdevnotes.blogspot.com/2008/...parameter.html
Now I whith my colleagues work on integration Axapta with the other business application named M&F (Management and Finance). Our company uses M&F for more than eight years and now it is time for new ERP system. This application has 2-tier architecture, and its business logic is on the server side. We use stored procedure API for document exchange from Axapta to M&F. Some days ago I tried to call stored procedure on MS SQL Server from X++. For several parameters it was necessary to set null value. At first I instantiated COMVariant like this:
COM parameter = new COM("ADODB.Parameter");
COMVariant nullParam = new COMVarian(ComVariantInOut::In, ComVariantType::VT_NULL);
parameter.name("@paramName");
parameter.type(#adInteger);
parameter.value(nullParam); // This method throw exception!
After several hours research I found decision of this problem:
nullParam = new COMVariant();
nullParam.variantType(ComVariantType::VT_NULL);
parameter.value(nullParam); // This method doesn`t throw exception now!
I think problem is in constructor of the COMVariant class. What is your opinion?
Developer notes: Inventory closing make corrections for transactions in closed periods Blog bot DAX Blogs 2 15.07.2008 20:52
Developer notes: Be careful whith Collections and Maps in Axapta Blog bot DAX Blogs 0 13.05.2008 19:05
Developer notes: Write InfoLog to database Blog bot DAX Blogs 0 03.05.2008 08:16
Developer notes: Why debit and credit turnovers different in Ledger and Inventory modules? Blog bot DAX Blogs 0 03.05.2008 08:16
Часовой пояс GMT +3, время: 19:25.
