Старый 09.07.2008, 22:05   #1
gatesasbait: Custom label on SysTableLookup column
Источник: http://gatesasbait.spaces.live.com/B...B9F5!236.entry
Good evening,
This shows how to put a custom label on a SysTableLookup:
public static void lookupSalesId(FormStringControl _ctrl)
    SysTableLookup sysTableLookup =
        SysTableLookup::newParameters(tablenum(SalesTable), _ctrl);
    Query query = new Query();
     query.addDataSource(tablenum(SalesTable));
     //'true' is used to specify which field we are returning from the lookup.
     //By default the first field added is returned, so here 'true' is superfluous.
     sysTableLookup.addLookupfield(fieldnum(SalesTable, SalesId), true);
     //Use this setLabel() call right after the adding the field you need to customize
    sysTableLookup.setLabel("My custom SalesId label");
     sysTableLookup.addLookupfield(fieldnum(SalesTable, SalesName));
     sysTableLookup.parmQuery(query);
    sysTableLookup.performFormLookup();
Normally, you would define this static lookupSalesId() method on the table SalesTable, since it is closely related. Then you could call this method from a form by overriding the lookup() method of a Form's Data Source field as such (logically, a field of the same type as the one you're looking up):
 public void lookup(FormControl _formControl, str _filterStr)
     SalesTable::lookupSalesId(formControl);
Creating Custom Dynamics AX Services Blog bot DAX Blogs 0 17.12.2008 12:05
DynaMihamAX: Label import problem in Dynamics AX 4.0 Blog bot DAX Blogs 0 12.12.2008 13:05
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
axaptapedia: Multi Column Blog bot DAX Blogs 0 05.02.2008 17:25
Часовой пояс GMT +3, время: 03:50.
