Старый 07.03.2009, 00:05   #1
axStart: Check if the table field is mapped.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!482.entry
Let’s have a look at the next scenario:
•             I have added a new field on my table map.
•             This new field not used on al the tables that use this table map.
•             I use this mapped field inside my table method.
If you don’t check it, you get an error about field ID is zero and you are not in the mood to check for all places where this method is use. And you don't want to change AX on all those places
Solution:
TreeNode::findNode(#TableMapsPath+'\\Map\\Mappings\\'+tableid2name(this.TableId)+'\\Field');
If the TreeNode exist the field is not mapped.
Example:
public static void initMapFromMap(AddressMap _toAddress,
                                  AddressMap _fromAddress)
   #AOT
    _toAddress.Address          = _fromAddress.Address;
    _toAddress.Street           = _fromAddress.Street;
    _toAddress.ZipCode          = _fromAddress.ZipCode;
    _toAddress.City             = _fromAddress.City;
    _toAddress.County           = _fromAddress.County;
    _toAddress.State            = _fromAddress.State;
    _toAddress.CountryRegionId  = _fromAddress.CountryRegionId;
    if(TreeNode::findNode(#TableMapsPath+'\\AddressMap\\Mappings\\'+tableid2name(_toAddress.TableId)+'\\Telex') &&
       TreeNode::findNode(#TableMapsPath+'\\AddressMap\\Mappings\\'+tableid2name(_fromAddress.TableId)+'\\Telex'))
           _toAddress.Telex            = _fromAddress.Telex;
palleagermark: Dealing with changed table or field id's Blog bot DAX Blogs 0 11.02.2009 11:05
axStart: table & field ID conflicts Blog bot DAX Blogs 0 29.05.2008 17:05
axStart: How to convert a column in a table to a different type with the same name without losing data. Blog bot DAX Blogs 0 01.02.2008 21:21
casperkamal: Adding a Table field through X++ code in Dynamics Ax Blog bot DAX Blogs 1 02.04.2007 17:05
Часовой пояс GMT +3, время: 23:49.
