#1 |
Axapta 3.0 SP4, две таблицы на гриде связаны по InnerJoin. Кликаю на хедер поля ZipCodeId второй таблицы. Сортировка вроде отрабатывает, но визуально записи расположены в беспорядке:
Код: BH14 8DW LA8 0NJ YO7 3NL DL10 5JU YO7 4AZ CA3 9SU CA1 2LW BD24 9NT Код: <Query Name="" Title="" Form="SysQueryForm" UserUpdate="Yes" Version="11" Literals="Default" Interactive="Yes" AllowCheck="Yes" RecordLevelSecurity="Yes" NextUniqueId="1002" >
<methods />
<Data_Sources>
<datasource Name="Table1" Table="Table1" UniqueId="1000" Company="" FirstOnly="No" FirstFast="No" AllowAdd="All_fields" OrderMode="Order_by" FetchMode="1:n" JoinMode="InnerJoin" Update="No" Relations="No" Enabled="Yes" >
<fieldlist Dynamic="Yes" >
</fieldlist>
<order>
<SortOrder>
</SortOrder>
</order>
<Ranges>
</Ranges>
<Data_Sources>
<datasource Name="Table2" Table="Table2" UniqueId="1001" Company="" FirstOnly="No" FirstFast="No" AllowAdd="All_fields" OrderMode="Order_by" FetchMode="1:1" JoinMode="InnerJoin" Update="No" Relations="No" Enabled="Yes" >
</fieldlist>
<order>
<field Table="Table2" Field="ZipCodeId" Ordering="DESCENDING" AutoHeader="No" HeaderDetailLevel="Auto" AutoSum="No" SumDetailLevel="Auto" />
</order>
<Ranges>
</Ranges>
<Data_Sources>
</Data_Sources>
<Relations>
<association Table="Table1" RelatedTable="Table2" Field="Field1" RelatedField="Field1" />
</Relations>
</datasource>
</Data_Sources>
</datasource>
</Data_Sources>
</Query>select из джоба сортирует верно: X++: static void Job12(Args _args) { Table1 table1; Table2 table2; int i; ; while select table1 join table2 order by ZipCodeId where table2.Field1 == table1.Field1 { i++; info(strfmt("%1,%2", i, table2.ZipCodeId)); if (i>1000) break; } } |
