Старый 03.07.2009, 07:05   #1
dynamic-ax.co.uk: Dynamics AX: Counting Lines of Code – Mohammed Rasheed
Источник: http://dynamic-ax.spaces.live.com/Bl...4DE3!426.entry
It recently downed upon me that I do not have an account of the number of lines of code I have written on my vpc (my Dynamics AX Playground!!).... Unfortunately I could not find an easy way to get an accurate count of the lines of code I wrote.. Hence i wrote some more code :)
Its like writing code to count code!!
Hope this is of help to others out there.. asking themselves the same question.
class mrCountLinesOfCode
Map axTypeCount;
Map mrTypeCount;
MapEnumerator axEnumerator;
MapEnumerator mrEnumerator;
str fullPath;
int pos;
int total;
int linesOfCode;
void run()
TreeNodeiterator tempNodeIterator;
TreeNodeiterator treeNodeIterator;
TreeNodeiterator rootNodeIterator;
TreeNodeiterator childNodeiterator;
str type;
TreeNode treeNode;
TreeNode rootNode;
TreeNode childNode;
TreeNode tempNode;
#AOT
rootNode = TreeNode::rootNode();
rootNodeIterator = rootNode.AOTiterator();
rootNode = rootNodeIterator.next();
axTypeCount = new Map(types::String,types::Integer);
mrTypeCount = new Map(types::String,types::Integer);
while(rootNode)
type = rootNode.treeNodeName();
childNode = rootNodeIterator.next();
childNodeIterator = childNode.AOTiterator();
treeNode = childNodeIterator.next();
while(childNode)
tempNode = treeNode;
tempNodeiterator = tempNode.AOTiterator();
while(treeNode)
// loop till you get to a leaf node - as methods are leafs
while(treeNode.AOTchildNodeCount() > 0)
if(treeNode.AOTiterator().next().AOTchildNodeCount()> 0)
treeNode = tempNodeiterator.next();
if(!treeNode)
treeNode = tempNode;
treeNode = treeNode.AOTiterator().next();
if(!treeNode)
// so we found a Lefe. check if its a method
if(sysTreeNode::hasSource(treeNode))
while(treeNode)
treeNode = tempNodeiterator.next(); // iterate first.
this.setCount(treeNode,type);
if(!treeNode)
if(!treeNode)
}// end if Has Source
else
treeNode = tempNodeiterator.next(); // leaf is not a method.. hence move to the next node
//childNode = rootNodeIterator.next();
if(!treeNode)
while(childNode && !this.checkIfNodeMightHaveCode(childNode.sysNodeType()))
if(childNode)
rootNode = childNode;
}// end root while
this.printitOut();
void setCount(treeNode _treeNode,str _type)
int tempLines;
fullPath = sysTreeNode::getPath(_treeNode);
pos = 0;
pos = strScan(fullPath,'\mr',1,strlen(fullPath)); //i always prefix any new elements i create with MR
tempLines = this.getLinesOfCode(_treeNode.AOTgetSource());
if(tempLines > 4)
if(pos)
this.countMrLines(tempLines,_type);
else
this.countAXLines(tempLines,_type);
int getLinesOfCode(Source _source)
Source tmpSource;
Line line;
int ptr;
int numberOfLines;
if (_source)
tmpSource = _source;
while (tmpSource)
line++;
ptr = strfind(tmpSource, '\n', 1, maxint());
if (!ptr)
ptr = strlen(tmpSource);
numberOfLines++;
tmpSource = strdel(tmpSource, 1, ptr);
return numberOfLines;
Source tmpSource;
Line line;
int ptr;
int numberOfLines;
if (_source)
while (tmpSource)
line++;
if (!ptr)
numberOfLines++;
void countMrLines(int _lines,str _type)
linesOfCode = 0;
if(mrTypeCount.exists(_type))
linesOfCode = mrTypeCount.lookup(_type);
linesOfCode += _lines;
mrTypeCount.insert(_type,linesOfCode);
boolean checkIfNodeMightHaveCode(int _sysNodeType)
#TreeNodeSysNodeType
switch(_sysNodeType)
case #SysNodeTypeTableCollection :
case #SysNodeTypeSystemEnum :
case #NT_DBCOLLECTIONLIST :
case #NT_DBFIELDGROUPLIST :
case #NT_DBENUMLIST :
case #NT_DBREFERENCELIST :
case #NT_CONFIGURATIONKEYLIST :
case #NT_SECURITYKEYLIST :
case #NT_DBLICENSECODELIST :
case #NT_MENU :
case #NT_DBLICENSECODE :
case #NT_CONFIGURATIONKEY :
case #NT_SECURITYKEY :
case #NT_TYPE :
case #NT_REFERENCE :
case #NT_PERSPECTIVE :
case #NT_PERSPECTIVEFIELDLIST :
return false;
default:
return true;
// just in case
return true;
  Technorati Tags: Dynamics AX 2009,Dynamics AX Code,TreeNode
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
AX UK: Microsoft Dynamics AX 3.0 to 2009 Data and Code Upgrade Training Blog bot DAX Blogs 1 03.02.2009 11:15
Часовой пояс GMT +3, время: 00:37.
