Старый 19.08.2009, 05:08   #1
lcash: Electronic Signature
Источник: http://blogs.msdn.com/lcash/archive/...signature.aspx
I had a note from Chuck to remind people about the use of Electronic Signature on the demo VM. You will note that the configuration key is turned off. So to set it up you will need to turn it on.
So navigate to Administration\Setup\System\Configuration.
Check the config key. Click Ok and let the sync go through.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash
lcash: Using Project Time Sheets setting up the Period Code Blog bot DAX Blogs 0 31.07.2009 06:16
lcash: ProjPost Class compile error Blog bot DAX Blogs 0 24.07.2009 04:20
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
mscrm4ever: CRM 4.0 Embedding User Signature in CRM Web Client Blog bot Dynamics CRM: Blogs 0 31.05.2009 06:07
Часовой пояс GMT +3, время: 13:49.
