Старый 31.10.2009, 01:22   #1
In the Classic client, in either the Alter Database or New Database window, one of the options on the Options tab is Enable for Microsoft Dynamics NAV Server. This option should be selected if you are deploying the RoleTailored client, which communicates with the database through the NAV Server. When this option is selected, access to special properties and .NET code that NAV Server computers must use to access the database is enabled. The option is selected by default; you would clear this option if you knew for sure that all database access would be through classic architecture components such as Classic client and Classic Application Server.
Источник: http://feedproxy.google.com/~r/Micro...er-option.aspx
Часовой пояс GMT +3, время: 20:16.
