Старый 29.11.2009, 23:03   #1
I received a question from a customer, who is running multiple companies and often have multiple instances of NAV open with different companies. On the main page, they do have information about what company is the active:
but when they have opened a number of Task Pages in the various instances of NAV, they cannot distinguish one from the other.
Example:
This image tells you the page and the Customer name – and you can easily identify the right page when Alt+TAB’ing between pages, but if you have multiple companies this doesn’t help you a lot.
So what determines the caption?
The fields used in the caption on a page is determined by:
DataCaptionExpr on the page. This is an expression, which can use fields, functions etc. to build up a caption. If that isn’t defined, the client looks for
DataCaptionFields on the page. This is a collection of fields, which are used to build the caption by adding them together with a character 183 (middle dot) between them. If that isn’t defined, the client looks for
DataCaptionFields on the table, which basically is the same as DataCaptionFields on the page.
In a standard NAV, there is no DataCaptionExpr nor DataCaptionFields defined on the Customer Card, but on the Customer table you find:
In order to add the Company name behind the caption you will need to change the DataCaptionExpr on the Customer Card to f.ex.
"No." + ' · ' + Name + ' ['+COMPANYNAME+']'
which would cause the Customer Card to look like
You can of course select to change the expression to whatever you like – or maybe create some function, which automagically returns a caption, only real flipside is that you need to modify the card pages, on which you need this functionality. In the end this is probably not a very large number.
Enjoy
Freddy Kristiansen
PM Architect
Microsoft Dynamics NAV
Подробнее
Часовой пояс GMT +3, время: 00:28.
