Старый 03.12.2009, 15:56   #1
Problem:
When previewing a report you only getting a small window in upper left corner with only a text string with the name for the report and the rest blank. When I trying to close this window, you get an error message: "Errors exist. Do you want to discard changes?" (Y/N). Pressing Yes, hangs and close the RTC client.
Probably cause:
You have installed the RTC client outside the setup chainer or you have uninstalled Report Viewer 2008. It may also be that Report Viewer 2008 installation is broken.
Solution:
Run DVDPrerequisite ComponentsMicrosoft Report Viewer 2008 ReportViewer2008.exe and select install or repair depending on if Report Viewer 2008 was already installed.
Источник: http://feedproxy.google.com/~r/Micro...g-reports.aspx
Часовой пояс GMT +3, время: 18:33.
