Старый 08.12.2009, 08:34   #1
Solutions Monkey: UpdateOnPostBack property of AXForm
Источник: http://blogs.msdn.com/solutions/arch...of-axform.aspx
If you need to read the values that the user entered in a text box before the record is committed to filter the possible values for the second text box then first you should set the autopostback property of the AxBoundField to true. Also you need to set the UpdateonPostback property of the AXForm.
UpdateonPostback property is set if the record cursor needs to be updated when post back happens, so that other controls could read the change. You could then use the row.GetFieldValue("FieldName") to get the value that that user entered in the text box.
Solutions Monkey: AxPopup Controls in EP Blog bot DAX Blogs 0 22.09.2009 11:05
Solutions Monkey: EP Page Life Cycle Blog bot DAX Blogs 0 18.02.2009 08:05
Solutions Monkey: Aggregation in EP Datasets Blog bot DAX Blogs 0 07.10.2008 06:05
Solutions Monkey: Role Center Security Blog bot DAX Blogs 0 28.05.2008 16:05
Solutions Monkey: EP 4.0 Questions Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 01:28.
