Старый 16.04.2010, 04:06   #1
kamalblogs: Debugging form controls in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
The X++ debugger doesn’t get invoked when placing breakpoint(ctrl+f9) in form controls.
There have been quite a few suggestions to work around this like the one mentioned one below
http://axdaily.blogspot.com/2010/04/...ed-method.html
http://blogs.msdn.com/x/archive/2009...orkaround.aspx
I have also a suggestion which i think can be slightly better also.
Add a method called bp() to global.
static void bp()
Now when you want to debug  a formcontrol, type bp() there and  place a breakpoint(ctrl+f9) in the global method.
This will invoke the debugger without any issue.
The advantage here is
>> You need not bother about “breakpoint”  in the code that is shipped.
>> With hardcoded breakpoints you cannot stop them when you want the code to execute, but with this bp() method you can easily remove it  as it is just (ctrl+f9) based.
>> At the end typing bp() is easy then typing breakpoint
kamalblogs: Setting up Form size during runtime in Dynamics Ax Blog bot DAX Blogs 0 07.04.2010 20:05
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 14:10.
