Старый 22.04.2010, 23:05   #1
Dynamics AX Sustained Engineering: How to prevent transaction reversal from posting to closed dimensions
Источник: http://blogs.technet.com/dynamicsaxs...imensions.aspx
Current behavior of Dynamics AX allows for transaction reversals to post without a warning or error message when the reversal will post to a dimension that is closed. If you wish to have a message appear to stop the reversal, this can be achieved by making the following modification. Please note that the reversal process will be blocked by this code if the posting will affect a closed dimension so you will need to create an entry manually through a journal to reverse the effects of the transaction originally intended to be reversed.
The change would be made to \Classes\LedgerVoucherTransObject\check.
// Find the account and then call the instance based nethods to validate the account.
ledgerTable = LedgerTable::find(ledgerTrans.AccountNum);
ok = ledgerTable.checkPostingType(ledgerTrans.Posting,false) && ok;
ok = Dimensions::checkDimension(ledgerTrans.Dimension, true,
_ledgerVoucher.parmCheckBlockedDimensions()) && ok;
ok = LedgerTable::checkDimension(ledgerTrans.AccountNum, ledgerTrans.Dimension) && ok;
ok = appl.dimensionSetValidation(false, company).checkDimension(ledgerTrans,
fieldnum(LedgerTrans, Dimension),
false, false, true) && ok;
ok = ledgerTable.checkUserId(curuserid()) && ok;
ok = ledgerTable.checkAccountCurrency(ledgerTrans.CurrencyCode,
(ledgerTrans.Posting == LedgerPostingType::ExchRateGain ||
ledgerTrans.Posting == LedgerPostingType::ExchRateLoss)) && ok;
// Validating amount
To:
//Validate dimension
Dynamics AX Sustained Engineering: Performance issue in "Open Transaction Edit" form Blog bot DAX Blogs 0 26.10.2009 20:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Inside Dynamics AX 4.0: Transaction Semantics Blog bot DAX Blogs 0 31.10.2007 23:40
Часовой пояс GMT +3, время: 22:42.
