Старый 01.06.2010, 15:05   #1
workflowax: What is a workflow owner used for?
Источник: http://workflowax.wordpress.com/2010...wner-used-for/
When creating new workflow configurations in AX one of the first fields that you are required to fill in named ‘Owner’. But what exactly is the use of this field?
For those of you have been using workflow for a while you have probably started to find some of these uses. But for those of you who haven’t found them yet here are my observations:
Definition of a workflow owner: The owner of a workflow configuration is the user within Dynamics who is responsible for monitoring, maintaining and ensuring that workflow instances run smoothly and are completed in a timeous manner.
Pre-requisites for workflow owner users:
  1. Must be a user in Dynamics AX.
  2. Must be an active user (necessary for creating the configuration and receiving notifications etc about failed workflows).
    NB: making the user inactive after setting them as the workflow owner will work, but nobody will then be aware if issues arise.
  3. Must be linked to an employee (otherwise errors will occur stating the user has no relationship defined)
  4. Should have email alerts activated and correct email address setup (user options form) so that they can receive notifications of workflow issues.
Functions of workflow owners:
  1. Modify the workflow configuration.
  2. Receives notifications/alerts about webservice failures.
  3. Receives notifications/alerts about workitem failures.
  4. Can be used for assignment when using the role based option (assign to Workflow Owner)
  5. Can be used for escalation of workitems. E.g. If the work-item has not been actioned then it is the responsibility of the workflow owner to approve or reject.
  6. Can be chosen as the “Start From” user when using Heirarchy based assignment.
  7. Can be chosen as the recipient of custom workflow/workitem notifications e.g. Completed, Started, Stopped etc…
  8. Can be used as a field in workitem instructions, subjects and emails.
So far these are the uses and functions of the workflow owner that I have found through my wanderings in workflow configurations. Please feel free to add to this list or provide corrections where necessary.
Happy Wanderings
workflowax: Enabling Workflow Configurations for different modules Blog bot DAX Blogs 0 23.05.2010 08:06
workflowax: Dynamics AX Workflow 4.0 Preview Blog bot DAX Blogs 0 23.05.2010 08:06
Microsoft Dynamics CRM Team Blog: Workflow E-mail Utilities Blog bot Dynamics CRM: Blogs 0 16.12.2008 23:05
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Arijit Basu: AX 2009 Workflows: A Quick overview Blog bot DAX Blogs 0 19.06.2008 02:07
Часовой пояс GMT +3, время: 10:14.
