Старый 30.09.2010, 10:34   #1
zhan is offline
zhan
Список измененных объектов DAX4.0 vs DAX2009
Коллеги,
на просторах интернета я нашел Excel документ, в котором описаны изменения объектов системы в DAX2009 по сравнению с DAX 4.0.
Возможно, что список не полный, но возможно он буден кому-то полезен.
This list of changed application elements compares objects in Microsoft Dynamics AX 4.0 (SP2) to the same elements in Microsoft Dynamics AX 2009.
This information is provided to assist you with a workload expense estimate before completing an upgrade from Microsoft Dynamics AX 4.0 (SP2) to Microsoft Dynamics AX 2009. After you identify the elements that have changed between versions, you should use the Compare tool and Code Upgrade tool to determine how the element has been changed. For information on how to use the Compare tool and Code Upgrade tool, see the Microsoft Dynamics AX 2009 Implementation Guide.
Within the worksheet for each type of element, you can filter on the Status column to determine whether the element is New, Changed, or Deleted.
The categories of comparison are:
• Classes - This category lists application classes and methods that have changed. Changes include, but are not limited to, changed IDs, names, additions and deletions. New and deleted classes do not have their members listed. Objects with changed names and changed IDs are highlighted in yellow. This information is particularly important before doing a code upgrade.
• Tables - This category lists application tables, table collections, and underlying table elements (field, field group, index, instance method, static method, and relation) that have been changed. Objects with changed names and changed IDs are highlighted in yellow. This information is particularly important before doing a code upgrade.
• Forms, Reports, Queries, Menus, Perspectives, Configuration Keys, Security Keys, Enums, Extended Types, Resources and References - Objects that are new,deleted, or changed are listed.
Note: This is a list of changed elements that compares objects from previous versions of Microsoft Dynamics AX to the same elements in Microsoft Dynamics AX 2009. While we have attempted to create a complete list, it has not been fully verified that all objects from the previous versions of Microsoft Dynamics AX being compared are included. We give no representation or guarantee to the accuracy or completeness of the content of this document.
На форуме он вроде бы не публиковался, я по крайней мере не нашел.
Но может быть плохо искал.
За это сообщение автора поблагодарили: lev (2).
Старый 30.09.2010, 14:55   #2
Maximin is offline
Maximin
NavAx
NavAx Club
415 / 361 (13) ++++++
Кажется, ссылка уже пробегала...
Толку с него всё равно маловато - он для английской версии, локализации там нет.
Жизнь прекрасна! Если, конечно, правильно подобрать антидепрессанты...
Старый 30.09.2010, 15:59   #3
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Post
Сообщение от zhan Посмотреть сообщение
Смысл перехода с 3.0 sp5 на 4.0 или 5.0
За это сообщение автора поблагодарили: zhan (1).
ax2009, документация
Перенос объектов DAX4 в DAX5 IvanS DAX: Функционал 14 27.11.2009 13:45
Список измененных (новых) объектов. Оптимизация. Alex_KD DAX: Программирование 2 29.02.2008 12:36
Просмотр недавно измененных объектов AOT Кирилл DAX: Программирование 5 02.10.2006 11:24
Как из Аксапты получить список всех доступных ActiveX объектов? chi DAX: Программирование 3 03.12.2004 15:16
Список полей таблиц на базе конкретного EDT Владимир Максимов DAX: Программирование 10 06.10.2004 14:45
Часовой пояс GMT +3, время: 08:53.
