Старый 02.11.2010, 13:05   #1
East Ocean - Technical: The RSA key container could not be opened
Источник: http://eastoceantechnical.blogspot.c...be-opened.html
Failed to decrypt using provider 'RsaProtectedConfigurationProvider'. Error message from the provider: The RSA key container could not be opened.
You hit the error when using encrypted web configuration section such as the connection string.
You can fix this with one of the following method:
1. I'm using Windows Server 2008
2. Open IIS
3. Navigate to the web site that is causing the problem
4. Under Security within the Home section of the web site, click Authentication
6. Disable ASP.NET impersonation
or
aspnet_regiis -pa "NetFrameworkConfigurationKey" "ASPNET"
aspnet_regiis -pa "NetFrameworkConfigurationKey" "NETWORK SERVICE"
aspnet_regiis -pa "NetFrameworkConfigurationKey" "NT AUTHORITY\NETWORK SERVICE"
aspnet_regiis -pa "NetFrameworkConfigurationKey" "NT AUTHORITY\SYSTEM"
East Ocean - Technical: Always focus on solutions, not on problems. Blog bot Dynamics CRM: Blogs 1 13.10.2010 16:25
East Ocean - Technical: Configuration registry key is invalid Blog bot Dynamics CRM: Blogs 0 22.09.2010 23:05
East Ocean - Technical: The path is not of a legal form - Data Migration Manager Blog bot Dynamics CRM: Blogs 0 11.08.2010 11:05
East Ocean - Technical: CRM 4.0 Update Rollup 10 Blog bot Dynamics CRM: Blogs 0 11.04.2010 19:07
Часовой пояс GMT +3, время: 09:43.
