Старый 16.11.2010, 22:11   #1
dax-ideas: Reading an XML file in AX 2009
Источник: http://dax-ideas.blogspot.com/2010/1...n-ax-2009.html
These days there are lot of requirements on Integration with other systems like in import data and export data. One of the means is XML .
Here is a small job to read an XML file in AX
static void ReadingXMLFile(Args _args)
XMLDocument XMLdoc = XMLDocument::newFile(@"C:\Users\nikhil.pujar\Desktop\Items.xml");
int i,CountItemtags;
XMLdoc.load(XMLdoc.toString());
info(XMLdoc.getElementsByTagName("number").item(0).text());
info(XMLdoc.getElementsByTagName("name").item(1).toString());
countItemTags = xmldoc.getElementsByTagName('number').length();
info (strfmt('Number of tags with name Item - %1', countItemTags));
for (i = 0 ; i < countItemTags; i++)
info ("Item number :" + xmldoc.getElementsByTagName('number').item(i).text());
info ("Item Name :" + xmldoc.getElementsByTagName('name').item(i).text());
emeadaxsupport: Identical AX 2009 AUC File Created For Multiple AX Installations Blog bot DAX Blogs 0 25.01.2010 16:05
Часовой пояс GMT +3, время: 17:33.
