Старый 16.11.2010, 22:11   #1
dax-ideas: Creating a new Item through Code
Источник: http://dax-ideas.blogspot.com/2010/1...ough-code.html
For Creating a new Item in AX 2009 we have to make a entry in four imp tables
They are
1) InventTable
2) InventTableModule
3) InventItemLocation
4) InventTxt
Below is a simple job which will create a new Item in AX 2009
static void Item(Args _args)
InventTable inventTable;
InventTableModule inventTableModule;
InventItemLocation inventItemLocation;
InventTxt inventTxt;
int counter;
inventTable.initValue();
inventTable.ItemId = "NIK-1000";
if(InventTable::exist(inventTable.ItemId))
throw error ("Item already exist,You cannot create duplicate items");
else
inventTable.ItemGroupId = "Television";
inventTable.ItemName = "LCD Plasma";
inventTable.ModelGroupId = "STD Cost";
inventTable.DimGroupId = "N-W";
inventTable.ItemType = ItemType::Item;
inventTable.insert();
<span style="color: blue;"><strong>for(counter=0; counter
За это сообщение автора поблагодарили: EVGL (-3).
dax-ideas: Reading an XML file in AX 2009 Blog bot DAX Blogs 0 16.11.2010 22:11
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
dynamicsaxtraining: Item setup: Item group Blog bot DAX Blogs 0 12.11.2009 17:05
dax-lessons: Problem when creating a dynamic form with ActiveX control & Solution :) Blog bot DAX Blogs 0 30.04.2008 16:05
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 15:13.
