Старый 28.12.2010, 19:12   #1
dax-ideas: Getting the list of datasource from the form
Источник: http://dax-ideas.blogspot.com/2010/1...from-form.html
Sometimes may be there would be need to get the names of the datasources used in the form . Here is a small snippet that would get you the list of the data source
static void datasources(Args _args)
FormRun formRun;
FormBuildDataSource fbds;
Args args = new Args();
Counter i;
args.name('Salestable'); //FormName
formRun = classFactory.formRunClass(args);
for (i = 1; i
dax-ideas: Creating a new form using code Blog bot DAX Blogs 0 23.12.2010 20:11
dax-ideas: Getting the List of Private and Shared projects from the Projects node using X++. Blog bot DAX Blogs 0 23.12.2010 20:11
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Часовой пояс GMT +3, время: 08:28.
