Старый 16.04.2011, 02:19   #1
Dynamics AX Sustained Engineering: Issue with check numbers when exceeding the upper limit of a 32-bit integer
Источник: http://blogs.technet.com/b/dynamicsa...t-integer.aspx
Problem:
When attempting to process a check which exceeds the upper limit of a 32-bit integer the following message is displayed: “The value is not within the range. Acceptable values are within the range 0 – 2147483647.”
Resolution:
To resolve this issue the following changes can be made.
1. Create a new 64-bit Extended Data Type to be used for checks
a. From the AOT navigate to \Data Dictionary\Extended Data Types
b. Right-click and select New -> Int64
i. Name = BankChequeStartNumInt64
ii. Label = @SYS23068
iii. HelpText = @SYS23068
iv. FormHelp = BankChequeLookup
v. DisplayLength = 10
vi. ConfigurationKey = BankCheque
c. Save the Extended Data Type.
2. Update NumberSeq Class to handle the new 64-bit integer
a. \Classes\NumberSeq\numInsertFormat
public static client server Num numInsertFormat(Integer                num,
                                                NumberSequenceFormat   format
    if (format == '')
        return int2str(num);
    if (!strfind(format, #SymbolLetters,1,999))
        return NumberSeq::numInsertFormatInternal(int2str(num), format);
    return NumberSeq::numInsertFormatLetters(num, format);
To:
public static client server Num numInsertFormat(Int64                num,
    if (format == '')
        return int642str(num);
        return NumberSeq::numInsertFormatInternal(int642str(num), format);
3. Update BankChequeCreate Class to handle the new 64-bit integer
a. \Classes\BankChequeCreate\dialog
public Object dialog()
    DialogRunbase dialog = super();
    dialogFromNegInstNum = dialog.addFieldValue(typeid(BankChequeStartNum), fromNegInstNum, "@SYS4083");
    dialogFromNegInstNum.lookupButton(0);
To:
    dialogFromNegInstNum = dialog.addFieldValue(typeid(BankChequeStartNumInt64), fromNegInstNum, "@SYS4083");
4. Update BankNegInstCreate Class to handle the new 64-bit integer
a. \Classes\BankNegInstCreate\classDeclaration
abstract public class BankNegInstCreate extends RunBase
    BankAccountTable        bankAccountTable;
    NumberSequenceFormat    format;
    CompanyBankAccountId    accountID;
    BankNegInstStartNum     fromNegInstNum;
    BankNegInstQty          numOfNegInst;
    DialogField             dialogAccountId;
    DialogField             dialogFromNegInstNum;
    DialogField             dialogNumOfNegInst;
    #DEFINE.CurrentVersion(1)
To:
    BankChequeStartNumInt64     fromNegInstNum;
    #DEFINE.CurrentVersion(2)
b. \Classes\BankNegInstCreate\parmFromNegInstNum
public BankNegInstStartNum parmFromNegInstNum(BankNegInstStartNum _fromNegInstNum = fromNegInstNum)
To:
public BankChequeStartNumInt64 parmFromNegInstNum(BankChequeStartNumInt64 _fromNegInstNum = fromNegInstNum)
c. \Classes\BankNegInstCreate\run
public void run()
    #OCCRetryCount
    BankNegInstStartNum toNegInstNum;
    BankNegInstNum      negInstNum;
To:
public void run()
    #OCCRetryCount
    BankChequeStartNumInt 64 toNegInstNum;
dynamics-ax-dev: Copying a Production Environment into a Development/Test Environment Blog bot DAX Blogs 0 02.12.2010 00:11
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Часовой пояс GMT +3, время: 01:15.
