Старый 07.07.2011, 22:12   #1
emeadaxsupport: COGS value on Sales Cube shows not correct value
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ect-value.aspx
We run lately in the issue when COGS value is not correct calculated for Sales Cube.
The problem occurs, when in Microsoft Dynamics AX are some return deliveries. For example 1 article will be returned as a negative position with a negative amount. The COGS field turns the negative amount into a positive (-4.000 $ -> +4.000 $).
That problem is in named query CustInvoiceTrans where we have following statement:
(SELECT ABS(SUM(COSTAMOUNTPOSTED)+SUM(COSTAMOUNTADJUSTMENT)) AS COGS
The correct statement should look in following way:
(SELECT -(SUM(COSTAMOUNTPOSTED)+SUM(COSTAMOUNTADJUSTMENT)) AS COGS
--author: Damien Maspero --editor: Czesława Langowska --date: 7/July/2011
Dynamics AX Sustained Engineering: Sales tax information is not recaculated if document date is changed in a journal when sales tax is calculated using document date Blog bot DAX Blogs 0 22.06.2011 08:13
emeadaxsupport: Measure 'Total purchases' in Accounts payable cubes for dimension 'Vendor Master' shows values Uknown Blog bot DAX Blogs 0 01.03.2011 22:11
emeadaxsupport: Dynamics AX OLAP cubes shows data only till 2008 year Blog bot DAX Blogs 0 07.02.2011 16:11
emeadaxsupport: Unable to validate workflow URL in AX 2009 - Get the following error: The request failed with HTTP status 405: Method Not Allowed Blog bot DAX Blogs 0 07.07.2010 23:05
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 13:32.
