Старый 18.12.2013, 21:11   #1
sashanazarov: Table inheritance and collection objects
Источник: http://sashanazarov.blogspot.com/201...n-objects.html
Be aware that there is an issue with storing child table records in collection objects like List.
If you have a table hierarchy and add a child table record to a List and then try to get it back, information from parent tables is lost, along with InstanceRelationType field value.
The following job reproes the issue:
static void tableInheritanceAndListBug(Args _args)
CompanyInfo companyInfo;
List companyInfoList;
ListEnumerator companyInfoEnumerator;
companyInfoList = new List(Types::Record);
select firstOnly companyInfo;
info(strFmt(
"Orig: RecId: %1, Name: %2, InstanceRelationType: %3",
companyInfo.RecId,
companyInfo.Name,
companyInfo.InstanceRelationType));
companyInfoList.addEnd(companyInfo);
companyInfoEnumerator = companyInfoList.getEnumerator();
if (companyInfoEnumerator.moveNext())
companyInfo = companyInfoEnumerator.current();
info(strFmt(
"List: RecId: %1, Name: %2, InstanceRelationType: %3",
companyInfo.RecId,
companyInfo.Name,
Output:
Orig: RecId: 5637151316, Name: Contoso Entertainment Systems - E&G Division, InstanceRelationType: 41
List: RecId: 5637151316, Name: , InstanceRelationType: 0
The workaround is to use buf2con function to convert the table buffer to a container, save the container in the list and finally use con2buf when fetching the value with enumerator.
static void tableInheritanceAndListBugWorkaround(Args _args)
companyInfoList = new List(Types::Container);
info(strFmt(
companyInfo.RecId,
companyInfo.Name,
companyInfoList.addEnd(buf2Con(companyInfo));
companyInfo = con2Buf(companyInfoEnumerator.current());
info(strFmt(
companyInfo.RecId,
companyInfo.Name,
Output:
List: RecId: 5637151316, Name: Contoso Entertainment Systems - E&G Division, InstanceRelationType: 41
За это сообщение автора поблагодарили: gl00mie (5).
buf2con, con2buf
Часовой пояс GMT +3, время: 05:33.
