Старый 01.11.2011, 03:13   #1
Two tricks about stopping AX service via PowerShell
Источник: http://alexvoy.blogspot.com/2011/10/...x-service.html
Generally speaking, it is true for all Windows services but my particular example is about stopping Microsoft Dynamics AX service (AOS) via PowerShell.
As recommended in Deploying customizations across Microsoft Dynamics AX environments white paper, before importing a metadata model store into the target environment, one must stop all AOS instances in it.
First trick is on how to provide the correct name of the service supposed to be stopped.
If you try to use the service name you see in Services, you will fail.
PS C:\Windows\system> Set-Service -name AOS60$01 -status stopped
Set-Service : Service AOS60 was not found on computer '.'.
At line:1 char:12
+ Set-Service -name AOS60$01 -status stopped + CategoryInfo : ObjectNotFound: (.:String) [Set-Service], Invali dOperationException + FullyQualifiedErrorId : InvalidOperationException,Microsoft.PowerShell.C ommands.SetServiceCommand
It is evident that the problem is in $ sign. To fix it you can simply quoted it with "'" (not with "!).
PS C:\Windows\system32> Set-Service -name 'AOS60$01' -status stopped
Unfortunately, this command does not work anyway because of an error:
Set-Service : Cannot stop service 'Microsoft Dynamics AX Object Server 6.0$01-a
x2012_std (AOS60$01)' because it is dependent on other services.
At line:1 char:12
+ Set-Service -name 'AOS60$01' -status stopped + CategoryInfo : InvalidOperation: (System.ServiceProcess.Service Controller:ServiceController) [Set-Service], ServiceCommandException + FullyQualifiedErrorId : ServiceIsDependentOnNoForce,Microsoft.PowerShell .Commands.SetServiceCommand
Nevertheless, you can stop the service as usual without any issue. I do not why it does not work but I would suggest that one use another commands to stop and start the service, namely:
PS C:\Windows\system32> Stop-Service 'AOS60$01'
WARNING: Waiting for service 'Microsoft Dynamics AX Object Server
6.0$01-ax2012_std (AOS60$01)' to finish stopping...
PS C:\Windows\system32> Start-Service 'AOS60$01'
6.0$01-ax2012_std (AOS60$01)' to finish starting...
It takes its time, be patient!
powershell
DynamicsAxSCM: Service products in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 2 02.06.2011 13:36
Часовой пояс GMT +3, время: 18:20.
