Старый 30.01.2012, 17:11   #1
sumitsaxfactor: Replacing Financial Dimension in Ledger Dimension–Version 2 [AX 2012]
Источник: http://sumitsaxfactor.wordpress.com/...ion-2-ax-2012/
Friends, I had posted one article on replacing financial dimensions within a ledger dimension sometime back. The job there was big and endless. I did some more research and was able to condense it a bit.
Here is the modified job:
staticvoid replaceLedgerDimensions1(Args _args)
    #LedgerSHA1Hash
    DimensionSHA1Hash               hash; //To store the calculated hash for DimensionAttributeValueSet
    HashKey                         valueKeyHashArray[]; //To store the has key of dimension in question
    Map                             dimAttrIdx, dimAttrRecId; //to store the dimension index and backing entity type
    DimensionAttributeSetItem       dimAttrSetItem; // Contains the number of dimensions active for a account structure ledger
    DimensionAttribute              dimAttr; // Contains the financial dimensions records
    DimAttributeHcmWorker           dimAttrWorker; //Backing entity view for Employee type dimension
    DimensionAttributeValue         dimAttrValue; // Contains used financial dimension values
    DimensionAttributeValueSet      dimAttrValueSet; //Contains default dimension records
    DimensionAttributeValueSetItem  dimAttrValueSetItem; //Contains individual records for default dimensions
    LedgerDimensionAccount          sourceDimension = 5637145829, targetDimension; //Record Id DimensionAttributeValueCombination table in which attribute value is to be replaced
    DimensionDefault                sourceDefDimension, targetDefDimension; //To hold the default dimension combination from a Ledger dimension
    LedgerDimensionDefaultAccount   defaultLedgerAccount;
    DimensionEnumeration            dimensionSetId; //Record id for table that contains active dimensions for current ledger
    int     dimAttrCount, i;
    int     emplBackEntityType; //Stores the backing entity type for Employee type dimension
    //The employee backing entity will be the view DimAttributeHcmWorker
    emplBackEntityType = tableNum(DimAttributeHcmWorker);
    //Initialize the map to store the backing entity types
    dimAttrIdx = new Map(Types::Integer, Types::Integer);
    dimAttrRecId = new Map(Types::Integer, Types::Int64);
    //Get the record Id (dimension set id) for current ledger to find active dimensions
    dimensionSetId = DimensionCache::getDimensionAttributeSetForLedger();
    //Find all the active dimensions for current ledger except main account and store there
    //backing entity type in the map
    whileselect * from dimAttr
            orderby Name
            where dimAttr.Type != DimensionAttributeType::MainAccount
        join RecId from dimAttrSetItem
            where dimAttrSetItem.DimensionAttribute == dimAttr.RecId &&
                dimAttrSetItem.DimensionAttributeSet == dimensionSetId
        dimAttrCount++;
        dimAttrIdx.insert(dimAttr.BackingEntityType, dimAttrCount);
    //initialize hash key array to null
<span><font face="Consolas"><font size="2">    for (i = 1<font color="#000000">; i
sumitsaxfactor: Replace a Financial Dimension in Default Dimensions [AX 2012] Blog bot DAX Blogs 0 18.01.2012 11:11
dax-lessons: Segmented Entry Control on Forms in Dynamics AX 2012 [Ledger Dimension/Ledger account lookup X++] Blog bot DAX Blogs 0 12.11.2011 19:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 21:39.
