Старый 27.04.2012, 22:11   #1
ax-erp: Format real number
Источник: http://microsoft-dynamics-ax-erp.blo...al-number.html
A little job to convert a real number to char
public static str numtostr(real _r,int _numberofDecimal=2,str _Format = "")
str num;
if(!_Format)
switch(_numberofDecimal)
case 0: num = System.String::Format("{0:0}", _r); break;
case 1: num = System.String::Format("{0:0.#}", _r); break;
case 2: num = System.String::Format("{0:0.##}", _r); break;
case 3: num = System.String::Format("{0:0.###}", _r); break;
case 4: num = System.String::Format("{0:0.####}", _r); break;
case 5: num = System.String::Format("{0:0.#####}", _r); break;
case 6: num = System.String::Format("{0:0.######}", _r); break;
case 7: num = System.String::Format("{0:0.#######}", _r); break;
case 8: num = System.String::Format("{0:0.########}", _r); break;
case 8: num = System.String::Format("{0:0.#########}", _r); break;
case 10: num = System.String::Format("{0:0.##########}", _r); break;
else
num = System.String::Format(_Format, _r);
return num;
ax-erp: How to format your number the CLR style Blog bot DAX Blogs 0 27.04.2012 22:11
daxsol: Axapta Kernel Functions Blog bot DAX Blogs 1 16.05.2009 19:22
Часовой пояс GMT +3, время: 11:06.
